t5 to tko600 swap
RE: t5 to tko600 swap
You should check into a G-Force transmission kit, they handle the same power in a stock T-5 case. You will still need a new clutch (TKO style clutch) but everything else is the same so you don't HAVE to buy a new shifter but you probably should anyways. I would ask some of your friends that has a TKO and see if you can drive it. I've often heard they don't like the way they feel/shift.
Check these out before you set your heart on a TKO.
http://www.g-forcetransmissions.com/default.htm
and
http://www.astroperformance.com/
and
Matt's 95 Stang
10-05-2015 07:16 AM
