94 gt dies when i cut the wheel
i cut the wheel in any way and the car dies out i tried missing around with the trim screw and when the idle does not come down fast enough and same times still dies out . help ????????????
RE: 94 gt dies when i cut the wheel
hmm... powersteering maybe? i had this same problem on a car i had before. I figured out my problem though, the inside of the front tire was hitting the side of the LTs, for some reason it would almost make it stall if i didnt stop steering in that direction. any mods to the car?
Status: online i have my car at the tuning shop and he said i should of put a 65mm tb instead of a 70mm . he also said the 70mm is harder to tune the car with and i have all these things done to the are and the car has been at the shop for a week . is it that are to tune a 94 model. he is burning a chip for me . the chip is a superchip .
i bought a 302 bored over.040 to a 308 9.8:1 it has :
all forged interenals piston, i beams, rods.
- heads specs -
trick flow twisted wedged heads #51400002
61 cc combustion chamber
2.02 intake valve
1.60 exhaust valve
high rate valve spring 7,degrees lock manganese broze guides.
trick flow 1.6 roller rockers
--cam specs --
brand new trick flow track heat cam # 51402000
lift : 499 in intake / .510 in exhaust
duration : 275 intake / 2.79 exhaust
lobe separation : 112 degress
--add on to the engine--
cobra upper and lower intake manifold
bbk long tube headers
70mm throttle body edelbrock
75mm mass air pro-m
30lb injectors calibratred
255 fuel pump
bbk fuel pressure regualtor
i cant get it running right it has bad idle the air /fuel mixture is off and it dies out when coming to a stop .
what can i do to fix the problem i did not know until i took the car to the tuning shop and he said the same thing 94-95 are hard to tune with mods . but you see people do mods on them all the time . but they dont tell you anything of having problems with it when they did all the mods.
LivingInThePast
09-16-2015 12:20 PM
mrmrultimate
Texas Regional Chapter
09-10-2015 09:43 AM
