car slower!! after motor build
i have a 1992 mustang i pulled the motor out bored it .050over mahle 2relive ft pistons, 5 angle valve jobe heads, eagle H-beam rods, trickflow upper and lower(2500-6500rpm) , msd wires, police intercepter cam(IDLE-5000rpm)............ and now i cant even beat a stock 5.0stang. the car is way slower plezzzzzzz help me
RE: car slower!! after motor build
ORIGINAL: 92stang302 i have a 1992 mustang i pulled the motor out bored it .050over mahle 2relive ft pistons, 5 angle valve jobe heads, eagle H-beam rods, trickflow upper and lower(2500-6500rpm) , msd wires, police intercepter cam(IDLE-5000rpm)............ and now i cant even beat a stock 5.0stang. the car is way slower plezzzzzzz help me |
Wow thats just Crazy... Don't really know what to say??
Just realized you said it was .050 over...is that on a stock block? Stock blocks are better w/ .030 over, no more than .040 max. It's probably running H-O-T!
Why would you go with an upper thats 2500 - 6500 RPM? As mentioned above, the cam and intake aren't matched up very well. But either way, why didn't you go with the Trick Flow Street Heat or something thats IDLE - 5500.
is that a 60's block or a newer 302 ho block, .050 is kinda much, i dont thin kyou can go past .040 with a good block.
what are the specs on the police interceptor cam??? the 5.0 HO had the same cam in it no matter what vihicle it whent into, civilian or police. |
a 5 angle valve job on stock heads is a joke...alot of$$$
also why would you put that big of an intake on poor flowing heads? |
Just another example of somebody putting together a bunch of good parts that won't work well with each other...
Anyways, it should still run OK, so I would say start out by checking your timing, look for vacum leaks, fuel pressure, spark plugs and gap...just a few things to look over. |
i agree that he should have kept all upgrade parts in the same rpm band , but should it be slower than stock?
yes it is a stock block and i was origonaly going to put a bigger cam in it but i dropped it and broke it in halve
