Ok I have $8k to spend help me spend it
Ok guys I have 8 grand I can spend on the stang. It is all stock except for full exhaust. The motor has 136k miles on it. I was thinking of a crate motor and suspension upgrades to put the power to the ground. Any ideas would be a great help. If you have something in mind please give me a brand name and where I can get it at. Later on I plan on getting a TT setup so if I get an engine I would like to get 1 that would be a good match for running TTs. I am clueless when it comes to suspension so could use alot of advice in that area. I was also thinking of doing the 5 lug conversion with disc brakes all around. No sense in having alot of power if u can't stop it. If I go over 8k its ok but would like it to be around 10k at the most. Unless I see something I MUST have. Lol. Thanks alot guys. Can't wait to see what you all have to say.
Forgot to mention its a 88 Mustang GT. I will also be dong the MAF conversion.
RE: Ok I have $8k to spend help me spend it
i would go with a really good crate engine since u already have a couple of miles. it would help if u told us how much power u want to make. if its anything more than 500hp, then go with crate engine diffinately.
I wouldnt bother with a crate motor... they are built for the pasification of the masses....
start with a stout shortblock and build your own... youll get better power.
and i like the turbo idea... but stay away from twins, get a single instead
ORIGINAL: Creetan
Heres the engine you want
http://store.summitracing.com/partde...5&autoview=sku
Intake
Transmission
And then of course do the MAF conversion, change gears in your rear end, and then youll probably still have enough for your lug and brake conversion
Intake
Transmission
ORIGINAL: AdderMk2
ORIGINAL: randy78045
There is a difference between a crate motor and a custom built engine that comes in a crate...
ORIGINAL: AdderMk2
im building my own motor
ORIGINAL: AdderMk2
yea.... one sucks, the other costs an arm and a leg
ORIGINAL: AdderMk2
