tranny problems
Old 10-23-2006, 09:19 PM
88_5.0
88_5.0's Avatar
Default tranny problems
Hey guys, this crap just started yesterday. It's been harder than hell to put it into 1st gear at a stop light and difficult to shift into 2nd. I just thought that it was the cold weather but thats not it. Another problem is that technically if you are sitting still with the clutch pushed in, you should be able to put it into any gear (maybe except reverse). I was just sitting still with the car running, putting it through the gears and it would not go into 3rd- it just grinds. So, is there a transmission rebuild in my near future?
88_5.0 is offline
Old 10-23-2006, 09:28 PM
fourfivefour
fourfivefour's Avatar
Default RE: tranny problems
It sounds like your clutch is not dis engauging. Do you still have the stock plastic self adjusting clutch quadrant?
fourfivefour is offline
Old 10-23-2006, 10:33 PM
88_5.0
88_5.0's Avatar
no i have an aftermarket aluminum quadrant, havent checked that. Also at around 2k rpms (any gear) ive got a vibration in the shifter and the center of the car. Any ideas?
88_5.0 is offline
Old 10-23-2006, 10:40 PM
GaryBisiniere
GaryBisiniere's Avatar
i got the same damn problem i wish i knew what it was!
GaryBisiniere is offline
Old 10-23-2006, 10:41 PM
fourfivefour
It sounds like your cable is loose. Adjust it. If you dont have an adjustable cable get one. Check your motor mounts, trans mount, and u-joints.
GaryBisiniere
its not hard for me to put into gear tho... but it vibrates like craazzyy over 2gs. any ideas!?
Old 10-23-2006, 10:42 PM
GaryBisiniere
ive replaced both u joints and checked every mount
Old 10-23-2006, 11:27 PM
GaryBisiniere
any1?
Old 10-24-2006, 01:38 AM
GaryBisiniere
Old 10-24-2006, 01:53 AM
dimebag
dimebag's Avatar
tough w. everygear=clutch problem, possible its ALL your syncros, but highly unlikely
just a select few=syncros
vibrations=way to many options, ujoints, mounts, something bent, something outa place, etc, etc.
dimebag is offline
Quick Reply: tranny problems
