TPS Goofy?
TPS Goofy?
I got a "Check Engine" light this morning going to work. Coming home it went away though.
I plugged in my code reader just now and I get 2 numbers in my computers history, although system is O.K.
1. O2 sensors fault/rich
2. Operator error during Dynamic Repsonse Test/Wide Open Throttle not sensed
The rich reading does not bother me so much, but I was thinking that my TPS sensor is going goofy.
When I hoover around 1700 rpm my car bucks... especially when cold.
I called around for a price and it is $31 at Autozone and they say they can test my old sensor for me to make sure if it's bad.
What do you guys think? Anyone know why they had 2 different sensors for my year? Just curious.
RE: TPS Goofy?
No you can test it on your car key on engine off, you need a voltmeter. Look for the proper voltage at idle and at full throttle, and check for any dead spots where no voltage is outputted by the tps.
RE: TPS Goofy?
yes key on engine off, and to check the voltage in case u dont know how, set it to direct current obviously, then the positive goes to the green wire then the black to a ground , it should read between .9 and .99 volts, if not loosen the two screws and turn it until it does, im sure u know how to do this and im soundeing stupid but just making sure
ShaneB26154
35
03-04-2021 04:05 AM
69MustangCoupe393cid
10-03-2015 10:33 AM
Kenta08
09-02-2015 10:33 AM
