Removing those damn rear 12 pt bolts holding in the drive shaft!!!
#31
RE: Removing those damn rear 12 pt bolts holding in the drive shaft!!!
lift would help u alot...
anytime i get bolts stuck at work i just secure a wrench to it and hit it with this bigass hammer we got.
NOTHING stops the bigass hammer
#32
using a torch will let you know if you have a fuel/ vapor leak too [:'(]
whenever using a torch have a BIG FIRE EXTIGUISHER READY! THEY ARE ONLY $20 at walmart.
Now, you must do one at a time ! the torch needs to be on each bolt for 5 mins, it will turn cherry red and come right off.
While its bright red you may spray some pb blaster etc on it, but you have to act fast~.
#33
I did my car with a 1/2 drive and a 12mm socket and a piece of 1 inch EMT about 18 inchs long. I did my friends truck today and it was kind of tuff so we got out the impact came off with NO trouble at all.
Gary Ugarek
63
12-11-2015 02:01 PM
