H/C/I SWAP INFO
RE: H/C/I SWAP INFO
are you lookign for info on how to do it? If so, I would go to autozone and drop 19bucks on a haynes manual... it has all procedures the torques specs and such you will need that no one whill know off the top of thier heads
RE: H/C/I SWAP INFO
This Adobe PDF file here should walk you through the process. I'll be doing it myself shortly.
RE: H/C/I SWAP INFO
that depends on what your preference is as far as brand, what exactly you want to do as far as the setup, etc. AFR, edelbrock, canfield, trick flow make some nice heads. edelbrock, trickflow, holley are some popular intake manifolds. theres countless places to get cams. its all up to you, theres a huge selection
RE: H/C/I SWAP INFO
+1 The only benefit you get with buying a kit is taking the guess work out of it. And thats why they sell so many kits because there are so many lazy people out there who dont feel like doing a little research
RE: H/C/I SWAP INFO
ORIGINAL: 88BlueGT
RE: H/C/I SWAP INFO
LMAO its OK... whatever floats your boat bro!
Anyway, here is a good tech article on doing your own h/c/i swap.
http://www.allfordmustangs.com/techa...intakeswap.pdf
RE: H/C/I SWAP INFO
ORIGINAL: 88BlueGT
**points to the third post in the thread**
