car slower!! after motor build
Old 10-23-2006, 05:49 PM
92stang302
92stang302's Avatar
Default car slower!! after motor build
i have a 1992 mustang i pulled the motor out bored it .050over mahle 2relive ft pistons, 5 angle valve jobe heads, eagle H-beam rods, trickflow upper and lower(2500-6500rpm) , msd wires, police intercepter cam(IDLE-5000rpm)............ and now i cant even beat a stock 5.0stang. the car is way slower plezzzzzzz help me
92stang302 is offline
Old 10-23-2006, 05:54 PM
gspfunk
gspfunk's Avatar
Default RE: car slower!! after motor build
ORIGINAL: 92stang302
Part of it you just answered yourself...You have way too much intake for that cam. You need the stocker back on it...maybe port out the lower a little. There may be other issues as well, but your intake/cam combo is not helping you at all.
gspfunk is offline
Old 10-23-2006, 06:12 PM
Stanpower
Stanpower's Avatar
Wow thats just Crazy... Don't really know what to say??
Stanpower is offline
Old 10-23-2006, 06:27 PM
gspfunk
gspfunk's Avatar
Just realized you said it was .050 over...is that on a stock block? Stock blocks are better w/ .030 over, no more than .040 max. It's probably running H-O-T!
gspfunk is offline
samseed101
samseed101's Avatar
Why would you go with an upper thats 2500 - 6500 RPM? As mentioned above, the cam and intake aren't matched up very well. But either way, why didn't you go with the Trick Flow Street Heat or something thats IDLE - 5500.
samseed101 is offline
Old 10-23-2006, 06:59 PM
Nadelle
Nadelle's Avatar
is that a 60's block or a newer 302 ho block, .050 is kinda much, i dont thin kyou can go past .040 with a good block.
what are the specs on the police interceptor cam??? the 5.0 HO had the same cam in it no matter what vihicle it whent into, civilian or police.
Nadelle is offline
Old 10-23-2006, 07:21 PM
sassy7806
sassy7806's Avatar
a 5 angle valve job on stock heads is a joke...alot of$$$
also why would you put that big of an intake on poor flowing heads?
sassy7806 is offline
Old 10-23-2006, 08:21 PM
5.0stanger
5.0stanger's Avatar
Just another example of somebody putting together a bunch of good parts that won't work well with each other...
Anyways, it should still run OK, so I would say start out by checking your timing, look for vacum leaks, fuel pressure, spark plugs and gap...just a few things to look over.
5.0stanger is offline
Old 10-24-2006, 12:01 AM
95 BLOWN GT
95 BLOWN GT's Avatar
i agree that he should have kept all upgrade parts in the same rpm band , but should it be slower than stock?
95 BLOWN GT is offline
Old 10-25-2006, 05:35 PM
92stang302
92stang302's Avatar
yes it is a stock block and i was origonaly going to put a bigger cam in it but i dropped it and broke it in halve
Quick Reply: car slower!! after motor build
