Mass Air?
Old 10-25-2006, 11:15 PM
vristang
vristang's Avatar
Default RE: Mass Air?
According to the 5.0 Dyno Test book written by Holdener...
A larger MAF on a completely stock 5.0 is worth 5-7hp.
Using the stock 94-95 Mustang MAF is the best option if you are staying with 19lb injectors.
If you need larger injectors, then aftermarket is the only option (other than a custom tune).
jason
vristang is offline
Old 10-25-2006, 11:23 PM
7upedition
7upedition's Avatar
ORIGINAL: alec3369
so if i have a mass air meter calibrated for 24lb injectors.... i wont have to change the mass air meter if i go back to 19lbers? (sry to steal your thread)
If your mass air meter is cal'd for 24lb injectors your air supply is going to maintain a air/fuel ratio to support the duty cycle of a 24lb injector, same for 19's. So if the MAF is putting in air for 24lbs and the motors getting fuel from 19lb the motor will run lean.... because of the high air to fuel ratio... there are other things affecting this such as fuel pressure, timing, etc. but thats the basic idea, you can always spend $15 on a new sample tube from C&L for what size injectors you have.
7upedition is offline
Old 10-26-2006, 12:25 AM
Bagitupbaby
Bagitupbaby's Avatar
i got a stock 5.0, and i got a 95 cobra mass air sensor would that werk on my car? i dont have aftermarket injectors or a throttle body?
Bagitupbaby is offline
daltron
04-28-2016 08:10 PM
Lethaldosage423
10-19-2015 12:12 AM
Dokilar
15
10-16-2015 08:13 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
1996cobraconvertible
SVT Forums
09-30-2015 02:01 PM
Quick Reply: Mass Air?
