I need help!!!good so, I tested the power wires
Ok, my ingnition coil went out in my 87 5.0..I replaced it, it was messed up on the negative side, about 3 weeks later, the same thing happened but I thought it was the module, replaced it and found out that wasn't it so I replaced the coil, it started then when I shut it off it didn't turn back on but it still would try and turn over. Well, I went to test the coil, it was good so, I tested the power wires going to it and the positive was good but there was no way of testing the negative wire well, there is power going to the coil but, none coming out and both times the coil went out it was the negative side...
I just want to know why the coil is good but it's not sending spark out of it when it is getting power to it?
RE: I need help!!!good so, I tested the power wires
ORIGINAL: yournamehere
I take it this one is almost impossible to answer...Some one told me it could be my ground from my battery but it all looks good and clean. =/
im wondering if you are maybe having ECM troubles or even a bad PIP in the distributor
ORIGINAL: AdderMk2
you only posted a half an hour ago.... most people are still working on the west coast...
if your coil is good it means that your not getting a signal either to the ECM or FROM the ECM. A common failure in the 5.0 motor as far as spark goes is the PIP in the distributor. either rebuild your disty, or replace it
1.Take the connector off the coil, remove one wire from the connector, see all that white fuzz? or green fuzz? clean with electrical cleaner spray and make the tab fit tighter onto the coil by pulling out tab some.
2.still bad?remove the coil wire from dizzy, then ground, if she sparks replace the entire dizzy and ignition module.
Common on Ford Tempo, Taurus, Mustangs etc.
3. u say its getting power, your connecotr ,may still need to be straightened out. its also possible you were sold a bad module.
4. Also make sure she has a good ground on chassis
Faolan65
08-27-2015 06:40 AM
Faolan65
Arizona Regional Chapter
08-25-2015 09:24 AM
