bbk ssi intake
RE: bbk ssi intake
the EGR system is built into the intake itself, you dont use the EGR spacer plate
there is place on the upper intake behind and below the throttle body
to mount the EGR valve and sensor that normally moounts to the EGR spacer plate.
you will have to unscrew the electrical sensor and rotate it or "clock it"
so that when the valve is mounted the plug-in connector points out and down
you have to be careful and pack all the wiring harness and everything in tight
around the EGR valve to make sure everything fits and upper sits down squarely.
it's a real tight fit right there.
jwog666
12-27-2021 08:09 PM
daltron
04-28-2016 08:10 PM
bradleyb
11-27-2015 07:50 PM
