94 GT 302 Stock pinging!
Hello good gents,
I know there have been quite a few posts about this problem, but I just wanted to get a concensus about this topic.
I have tried the cleaning of the MAF sensor trick (although I have not taken it completly out of the housing). It does seem to help for a while.
I have recently replaced The Air Charge Sensor (no real difference). The guts of my 302 are bone stock & I don't have a cold air intake or chip mods. Does the O2 sensors make a play in the overall pinging? If so, I heard they can be cleaned with a torch (carbon deposits) or heavy duty solvent.
Thanks in Advance.
Thanks in Advance.
RE: 94 GT 302 Stock pinging!
What is the timing set at, what octane gas are you using and is the egr system working? Those directly affect pinging
This should keep ya busy for a while
http://www.streetrodstuff.com/Articl...ne/Detonation/
ORIGINAL: PRO50SC
So what actually pings when you hear that ping ? I was runnin 91 and 92 octane when i drove it last, but it was an all stock motor except for bbk LT's and bbk cai and bbk pulleys. So i really didnt need to run that high octane on a stock motor ? I just figured i would since it was a "race" motor, or whatever i thought back them, performance or some sht. Donno what i was thinkin, but i learned alot since then.
I also had to run premium in my old car ( 2.3L Quad 4 DOHC ) it ran like sht without it. So i figured if i did in that, why not in this, its even fast. HAHA.
ORIGINAL: Ninety5five0
I guess thats hwy my old car needed premium, it was 10.5:1 compression stock. I think P heads make compression a lil higher too, which is kindof good i guess. I'm sure the dyno shop will tell me what kindof fuel i'm gonna need to run, but i'm guessing its gonna be premium. Them bastard better squeeze out every pony possible, no fallen ponies are to be left behind .
Man, this thing is sooo close to being done, its frustrating. I cant wait to put that thing up on the dyno. I hope the place i plan on takin it to knows what theyre doing. They are a performance motor shop, so i guess they should, atleast i hope.
ORIGINAL: PRO50SC
ORIGINAL: 7upedition
Thats what i was thinking... reset base timing to 10*, set base idle, TPS voltage, clean IAC, and run some 89 or 91 octane for a tank and see what happens, then you'll know if your o2's are giving poor readings and creating a lean condition, jmo
ORIGINAL: PRO50SC
you mite try running 93 octang gas in it and if that dont work check egr and if that dont work retard your timing just a hair
[sm=massbounce.gif][sm=massbounce.gif]
1992 5.0
302 050 over
10.5:1 compresion
TF intake
eagle H-beam rods
msd ignition
1992 5.0
302 050 over
10.5:1 compresion
TF intake
eagle H-beam rods
msd ignition
