Fuel Pump
RE: Fuel Pump
What other mods do you have? I would run a 255 l/hr
If its a bone stock car with a blowr the 24's would be fine but if you have other mods I would consider stepping it up to something a little larger.
RE: Fuel Pump
I would upgrade your injectors. There is a calculator that I posted in the tech section called "understanding your efi system". Skim through that and there is a calculator in there that you can use. Remember, you dont want to exceed 85% DC because the injectors can become innaccurate and unstable after that. Check it out. I have a feeling you definetly should be upgrading to something bigger.
RE: Fuel Pump
Hey, for some reason HC took it off of the sticky list. I PMed him about it.
Here it is...
https://mustangforums.com/m_2128440/tm.htm
And Im also working on the second article that came out too. Hopefully it will go in the sticky section along with the one I just posted.
Here it is...
