How to do anti-theft kill switch?
RE: How to do anti-theft kill switch?
get a gt headlight switch and run the ignition power wire to the fog light switch. not many people will ever think of looking there. when you get in just turn on the fogs and start the car
I used a magnet as a kill switch in my car... its a pretty simple design yet very effective. Im running a bosch relay inline with my starter wire from the ignition switch. The system employs a reed switch mounted behind the dash. There is a certain spot that i have to put my key fob near for the car to start. Inside my key fob is not your normal keyless entry electronics.... but instead, a magnet from an olf tweeter i had laying around. It has enough magnetic pull to trigger the reed switch and send a 12v signal to the relay and allow me to start my car.
Google search "installing a kill switch" there are some pretty cool ideas out there. One is using the cigarette lighter push it in and you can start the car then pop it out to open the circuit. Kill the starter, fuel pump, or the park/neutral saftey switch for the transmission.
Matt's 95 Stang
10-05-2015 07:16 AM
