New Combo
New Combo
Ok, so the car is sleeping for the winter. Now It's time to order parts. Here is my combo i'm working on getting:
AFR 165 Heads
TFS Stage 1 Cam
Edelbrock RPM II Intake
Summit 1.7 Roller Rockers
I was wondering what parts I will need for the heads? Lifters, Pushrods ect. and what brand would be good with the combo?
Anything else you know I would need would be helpful.. thanks.
AFR 165 Heads
TFS Stage 1 Cam
RE: New Combo
Well I want to keep it N/A for now to work on the suspension/drivetrain. I'm wondering can i use my stock lifters or should I get new ones. Also what length pushrods. After all thats done I will get a custom cam made for a supercharger....
RE: New Combo
CAM SPECS:
Basic Operating RPM Range: 2,000-5,500 RPM
Intake Duration at 050 inch Lift: 221
Exhaust Duration at 050 inch Lift: 225
Duration at 050 inch Lift: 221 int./225 exh.
Advertised Intake Duration: 275
Advertised Exhaust Duration: 279
Advertised Duration: 275 int./279 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.499 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510 in.
Valve Lift with Factory Rocker Arm Ratio: 0.499 int./0.510 exh. lift
Lobe Separation (degrees): 112
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer Controlled Compatible: No
Grind Number: HR-224/339-2S-12
Quantity: Sold individually.
RE: New Combo
the best thing to do is buy an adjustable pushrod length checker (its a tool that summit carries) and build your motor without any pushrods in it. then use the adjustable checker to find out exactly how long your pushrods need to be, then order the right ones to fit your application
Summit Pushrod length tool
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
