are my o2's bad read info inside(updated)
Old 10-28-2006, 10:51 PM
mustangfxbdy
mustangfxbdy's Avatar
Default are my o2's bad read info inside(updated)
UPDATE IN MY LAST POST
so i finally got a chance to run codes off the eec today and got a code
41 hego sensor indicates lean right side
91 no hego switching detected always lean left side.
so i reset the codes and ran it down the road came back
code 41 was back
so i reset again ran it at idle check codes no 41 this time
so i turned the timing from 12degree 10 degree( to see if i could get it to richen up a little) ran it down the road and still didnt get a code 41 this time either. im going to check it tommorrow to see if it came back after some driving tonight and tommorrow.
i was checking this due to my little miss issue when engine was not at full operating temp. i stated here https://mustangforums.com/m_2160898/tm.htm
the car seems to have more power now at WOT at 10 then it had at 12degree. and idles better. (go figure)
if code comes back it could be that the 02 sensors are bad.
cars running excellant with plenty of power but that doesnt necessarily mean that the 02's are good either.
what do you think
sorry for the book article here lol.
mustangfxbdy is offline
Old 10-28-2006, 10:54 PM
fourfivefour
fourfivefour's Avatar
Default RE: are my o2's bad read info inside
With both banks indicating lean I would look for a vaccume leak first before replacing sensors.
fourfivefour is offline
Old 10-28-2006, 10:58 PM
mustangfxbdy
thats what i was thinking but when i reset codes and ran it down the road it reset code 41 for right bank but when i turned the timing back down to 10 and ran it down the road no codes whatso ever and i pounded on it.
and car idles better now.
if code 41 comes back ill check for vacuum but I checked a week ago and didnt have one.
another thing i forgot to mention is i had the egr vaccum off when i got the codes 91 and 41 but when i reset codes first time i pluged the vaccum back up then got 41 then turned timing down and got no codes.
Old 10-28-2006, 11:30 PM
vristang
vristang's Avatar
Also check your grounds, in particular the orange ground on the drivers side firewall. It should be with the grounding strap coming off the block.
The salt and pepper connectors can get some corrosion as well, which can cause erratic codes.
How old are the O2's?
jason
vristang is offline
Old 10-28-2006, 11:38 PM
mustangfxbdy
they were put in when engine was installed about 7500 miles ago but thats also been since 03 previous owner didnt put hardley any miles on the engine...
but i still dont have any codes since then so ill wait till it comes back and investigate but shes running beautiful...
i wish i had an a/f gauge so i could see what shes doing. hopefully the code wont come back.
Old 10-29-2006, 12:54 AM
2 kwik
I ♥ Acer
2 kwik's Avatar
pull the o2's and clean them
2 kwik is offline
Old 10-29-2006, 01:43 PM
jaznasy69
jaznasy69's Avatar
check the O2
jaznasy69 is offline
Old 10-29-2006, 04:32 PM
mustangfxbdy
well believed i solve my issue
found orange ground wire was barely hanging on bellhousing
took it off and put it to firewall where other ground was turned my timing back to 12 degrees no codes now
plus checked my msd distributer cap and rotor button and all electrodes had bad burnt spots on them replaced dist. cap and button and she idles beautiful now.... but what i dont get is the msd dist cap was only around 6 months old???
any way car runs great now with no codes i do plan on cleaning my o2 sensors as soon as i can for good measure but no codes so everything is ok now .
thanks guys for all the replys
Old 10-29-2006, 05:26 PM
CrazyCobraSpeed
CrazyCobraSpeed's Avatar
just outta curiousity what do u clean O2 sensors with... since i been workin on my car and im waiting for my o2 sensor extenders to get hear i figures cleaning them mite be a good idea
CrazyCobraSpeed is offline
Old 10-29-2006, 06:22 PM
mustangfxbdy
take a small propane tank and burn them till they turn white.
djbigskrilla
09-20-2022 01:04 AM
drfister
05-03-2018 10:38 PM
YoungStangsMan
09-05-2015 07:01 PM
Kenta08
09-02-2015 10:33 AM
dba Brakes
08-21-2015 07:07 PM
Quick Reply: are my o2's bad read info inside(updated)
