clutch replacement kit
i was just wondering what peoples opinions were on this kit. having a little trouble with my transmission and thought this might do the trick. http://www.jegs.com/webapp/wcs/store...tegoryId=11251
RE: clutch replacement kit
Looks like a good deal. I changed all that on my coupe last weekend.
I would also suggest a new rear seal, pilot bearing, and a steel throwout bearing retainer.
If your having trouble shifting your syncros are going and your trans needs to be rebuilt.
ORIGINAL: 90lxstang
definitely having a little trouble shifting. also i have to put the car in reverse before i turn it on so it won't grind.
My 95 started howling as if the clutch or the clutch fingers were coming apart or worse falling into the clutch plate path. I replaced the whole assembly with a Centerforce Dual Friction only to find out that all the noise was the cheap Ford Racing throwout bearing.
No matter what kit you get, don't go cheap on that part... get a top shelf throwout bearing.
Jskeezy84
09-08-2015 01:40 AM
