trick flow track heat cam in a 94 having problems need help!!!!!!
is the trick flow track heat cam to be for my set up i have problems on idle and the car stals out and it pop threw the intake what can that be help .
- heads specs -
trick flow twisted wedged heads #51400002
61 cc combustion chamber
2.02 intake valve
1.60 exhaust valve
high rate valve spring 7,degrees lock manganese broze guides.
trick flow 1.6 roller rockers
--cam specs --
brand new trick flow track heat cam # 51402000
lift : 499 in intake / .510 in exhaust
duration : 275 intake / 2.79 exhaust
lobe separation : 112 degress
--add on to the engine--
cobra upper and lower intake manifold
bbk long tube headers
70mm throttle body edelbrock
75mm mass air pro-m
30lb injectors calibratred
255 fuel pump
- heads specs -
2.02 intake valve
1.60 exhaust valve
--cam specs --
75mm mass air pro-m
255 fuel pump
RE: trick flow track heat cam in a 94 having problems need help!!!!!!
94-95 5.0s hate aftermarket cams b/c of the computer sensativity, they almost never run well without a tune. I think that's the main reason they make computer compatible cams
I have heard that the 94-95 gts have problems with cam swaps. A dyno tune is usually the solution to that problem. But it could definately be something else. How did you degree the cam? Did you remember to put the crank gear at 12 o clock, and the cam gear at 6 o clock? What is your timing set at?
Do you have an adjustable valvetrain?
If you do, did you set the valve lash correctely? What i'm thinking is that the rocker could be set too tight and the valve may be staying open. That would give you the rough idle and the intake popping.
Recheck your rockers if they're adjustable. If it is not the rockers then it may be your timing chain not set right.
Look at these things and let us know.
Ryan
Ryan
ORIGINAL: 94gtmax50
i made up my mined and i am coverting it to a 93 setup the computer is more easy to work with .
i was actually having the exact same issue. mine was due to a few vacume leaks as well as my timing being to low. i brought it to a show and they quicky ran the dyno on it to make sure and it solved my issues. my best guess is the poping is cause there is not enough vacume. as everyone else said a dyno tune with a chip will set you straight and add prolly 20 hp
1. Remove the valve covers, and pick ANY cylinder you are going to START WITH.
2. Hand rotate the engine in its normal direction of rotation(CLOCKWISE 24MM SOCKET, ALSO HELPS TO REMOVE FAN OFF WATER PUMP, 11MM) and watch the EXHAUST valve on that particular cylinder(THE VALVE RIGHT IN FRONT OF THE HEADER EXIT).
When the exhaust valve BEGINS TO OPEN stop and adjust that cylinders intake rocker arm. (
spin the intake pushrod with your fingers while tightening down the rocker arm. When you feel a slight resistance to the turning of the pushrod, you are at Zero Lash
. Turn the adjusting nut down one full turn from that point. Lock the adjuster into position(IF APPLICABLE). The intake is now adjusted properly.
5. Continue to hand turn the engine, watching that same intake. It will go to full open and then begin to close. When it is almost closed, stop and adjust the exhaust rocker arm on that particular cylinder.
6. Both valves on this cylinder are now adjusted, and you can move on to your next cylinder and follow the same procedure again.
, redo this before getting a new ecm or tune
