fuel pump
fuel pump
i no longer have the owners manual so i have no idea which fuse is which, so which fuse controls the fuel pump? i need to remove it to release the pressure on the fuel system to replace the fuel filter because i believe it is clogged and im losing a lot of performance, thanks, just tell me like top row, third from the left or sumthin that'd be freakin awesome thx
RE: fuel pump
bah... who releases pressure these days.... its not a job well done unless you get a face full of fuel.
btw, you can also trip the inertia switch, then crank over the car and let it run.... or you could release the pressure at the schrader valve on the fuel rail
mrappe
09-26-2015 10:16 AM
