which roller rockers?
I am about to get my engine rebuilt. 90' lx vert aod
im going to tell my mechanic that i want a e303 cam with afr 165 heads. what kind of roller rockers should i use? and is this a good setup for daily driving? my mechanic disagrees and says that the computer might act weird. and also should i get a double timing chain?
any other parts i should have installed?
and would i be able to run the stock intake manifold, throttle body, and fuel system? till i get a little more cash? and what kind of fuel pump/injectore should i order?
i have a budget of about 5000
and i also want a set of longtubes, will they bolt up to a bbk offroad h pipe or will they have to be welded?
sorry for all of my n00b posts.
RE: which roller rockers?
ORIGINAL: Dull_Machete
im going to tell my mechanic that i want a e303 cam with afr 165 heads.E cam is okay, but I'd go w/ the TFS stage 1 instead. It has a little more duration and split lift on the int/exh
what kind of roller rockers should i use? and is this a good setup for daily driving? It's a great setup and you'll need stud rockers. Scorpion are very good for the price and are under 200 for stud mount.
my mechanic disagrees and says that the computer might act weird. The computer will be fine. The 94-95's 5.0's have the troublesome computers.
and also should i get a double timing chain? It should be standard for the 302, but yes you should.
any other parts i should have installed? See next answer
and would i be able to run the stock intake manifold, throttle body, and fuel system? till i get a little more cash? and what kind of fuel pump/injectore should i order? The stock manifold will bog you down bigtime w/ AFR's and a cam. Get a used Street heat or something off ebay. Your stock TB will be okay, but a 65mm would be better. You'll also want a larger MAF. Your stock fuel rails should be fine, but you may want to look into 24 # inj's in the near future (MAF calibrated for them, too). You'll want at least a 155lph fuel pump. Check out jdsperformance.com for good prices on Walbro pumps.
and i also want a set of longtubes, will they bolt up to a bbk offroad h pipe or will they have to be welded? They will bolt up if you have the shorty H pipe, made for longtubes.
I just went back to 1.6's b/c I had a lot of valvetrain noise. You'll need to check the piston to valve clearance to run larger rockers, which I don't think you'll be able to do since 1.7's would put the exhaust side around .542. If you do go w/ bigger rockers, use a pushrod length checker to make sure you get the right size.
ORIGINAL: gspfunk
+1
69MustangCoupe393cid
10-03-2015 10:33 AM
JDWalton
09-24-2015 08:47 PM
