Is this wat I think it says
I was just looking up how to Identify the rear axle in the CHILTON MUSTANG book. It says if the axle identification has W it means it has 3.73 Axle Ratio Limited-Slip. So does that mean sum stangs come with 3.73 gears already in or am I wrong?
RE: Is this wat I think it says
the housing itself will be same, but mounting location, control arm mounts, and axle length will be different, you'll be better off just buying some gear and a traclok
ORIGINAL: great 8
So is it possible that i could put a exploer rear end on my stang will it fit ?
-P.
