fixing to order a cam
Old 03-17-2003, 11:51 PM
mustangdave357
Default fixing to order a cam
Order the Motorsport Z-303, best cam I have ever had
mustangdave357 is offline
Old 03-18-2003, 03:47 PM
91GT5.0
lloyd, how much hp do u think the e-cam gave you? (Was it the same amount as gears, LOL) what was your set up?
91GT5.0 is offline
Old 03-18-2003, 05:41 PM
DougBlevins
is the f303 ok for a stock 5.0 engine? i was gonna go w/ the e303 but would like to go w/ the f cam if i could. what do ya'll think??
thanks
DougBlevins is offline
Old 03-18-2003, 06:08 PM
lloydchristmas
I never dynoed it after the cam was in. Thanks to the NOS explosion. (which was WAY cool by the way) But you definitely heard and felt a difference. It was a nasty cam. Check to see if the F has any piston to valve clearance problems. I dont think it does but im not 100% sure. Good luck with whichever you chose Doug.
lloydchristmas is offline
Old 03-20-2003, 11:06 PM
spike306
the e-cam is a mean *** cam, but if your going to use it on a motor w/ stock heads and nos, i would recomend the f-cam. also, i'm pretty sure that lloyd's right on the piston to valve clearance.
good luck with all that
spike306 is offline
Old 03-21-2003, 02:44 PM
DougBlevins
the f cam has like a 512 lift. so what do ya'll think that will b a problem? ya'll r really making me want that f cam now.
Old 03-21-2003, 09:04 PM
lloydchristmas
Call a Ford Motorsport dealer they will tell you if it will clear.
Old 03-22-2003, 06:27 PM
spike306
agreed!!!!
spike306 is offline
Old 03-24-2003, 03:45 PM
DougBlevins
new springs r a must when u put in a new cam; but do i really need to put in new lifters? (on a '90 5.0 with 190,000 original miles, but less than 5k miles after engine rebuild)
Old 03-24-2003, 09:35 PM
lloydchristmas
It cant hurt. Better than having to take the motor apart again Right?
Quick Reply: fixing to order a cam
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
