fixing to order a cam
i'm fixing to order a cam and have a few ?'s. should u get new springs and lifters if u get a new cam? and what kind of cam(brand) would everyone recommend?
i would say if you had good set of heads to get the e-303 or the f-303, but if your running nos, you might wanna talk to lloyd about that.
Doug, from what I understand if you have roller lifters you dont need to replace them with a cam change. I always do because I like to be careful. When running on the juice I always had good luck with the E-303. I also know alot of guys that shot their cars with a B-303 and they loved it. I like the FRPP cams myself.
i was thinking of going w/ the F cam. i want my car to sound MEAN when just idling or when driving. i want to make my stock motor preform better, but also have the cam i'll need when i get heads. what do u think about the f cam and lifting combo from comp cams and then a valve spring kit?
I had an E cam in my car and it sounded NASTY!!!! Lumpy as hell. Worked great with the nitrous too!!!
E cam lumpy and nasty??? that's what i want to hear... casue that is excatly the cam i want.... to go with my new heads that is....
did the e303 make your car run better when u weren't juicing at the time?
i had my engine rebuilt and don't have 5,000 miles on the rebuild yet, would i still need to do new valve springs and lifters when installing the new cam (probably the E303)
THe E cam is the shizzle!!!
Order the Motorsport Z-303, best cam I jave ever had
