How do I determine my redline?
I just thought of something. If I recall correctly, my redline is 5900 RPM and the rev limiter is 6250. (Not looking at it so not 100% sure.) But is there a safe way to determine what the redline is and what the reve limiter should be set to?
It's fine the way it is now, but in the very near future I will be upgrading the H/C/I. Once that it done, I should be able to get the RPMs slightly higher without floating the valves or anything. But how can I tell what that number is? Any little bit will help, especially on the top end. With 3.73's I can run out of gears pretty fast when at WOT. Right now my redline speed for 3rd gear at WOT is ~118 MPH and that just aint gonna cut it, lol. I know I could get bigger tires, but oh well.
SO basically, I'm just trying to figure out if theres a way to determine what the redline should be with a new setup.
RE: How do I determine my redline?
ORIGINAL: redneckstang
good point but it is not beneficial to rev past peak output
ORIGINAL: r.barn
i would not exceed 6,500rpm with out some serious valve train uprgades.
most street valve train set-ups will experience valve float at 5,500 rpm with out upgraded springs.
why not?...valve train/cam selection/and intake are the meat and potatoes of this figure..so when i'm at the track you are saying i should shift at or before my peak?
this would drop me into a weaker power band so why not say 5900 pk and shift at 6500? this would keep me in the hunt for my peak power.
ORIGINAL: grabbem88
high revs with the right cam will make big hp. but with big hp you need to upgrade the fuel system to support the power
JoshyGT
09-19-2017 08:52 PM
KingRando
10-01-2015 11:16 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
Cavedawg
09-17-2015 09:51 AM
