Got a PCV oil separator installed.
#24
RE: Got a PCV oil separator installed.
ORIGINAL: ttoppedaerocoupe
samseed, I have a quick question. (sorry to hijack thread for a minute) A buddy of mine has an old kawasaki ninja. When he first bought it, the PCV was one piece of tubing that was looped from a port on one side, around the tree, and back into the motor on the other side. When we first saw it, we thought something had to be wrong, so he cut it in half and has a filter stuck on the end, then it vents to the atmosphere. My whole group of friends that ride cannot figure out, however, why there was a vaccuum on the piece of hose when he first cut it. Then we thought maybe it was more of an equilizer between the heads, but still, why a vaccuum?? the bike got a HELL of a lot louder (sounded like a ****load of valvetrain chatter, then when you plug the hoses, the bike quiets down. Any ideas??
thanks a lot, alex
I guarantee there is no vacuum leak. I know this because I have a vac / boost gauge on my A-pillar and can monitor it constantly. If you pull the PCV valve itself you can get a vac leak, but that's completely different.
thanks a lot, alex
Vristang, I'll get at you later, as I have some things I want to discuss in detail regarding the topic.
#25
hey samseed did you lose any vacuum though routing it into the air as opposed to back into the motor? the guys i know that run it say the lose vacuum if they run a filter, so some run it back into the system. these are supras and DSMs so doesnt quite apply the same but ya
#26
Oh, by the way, Alex, to the best of my memory, that fresh air system is not in any way part of the PCV system--at least it wasn't on my bike; although the smog system on my bike had been removed long ago so that the only hose in that area was the pcv hose. Oh yeah...I just remembered...it's called an "Air Suction System." From the factory, there is some kind of canister that either pumps or sucks air into those valves for some emissions purpose. Yeah, the bike will sound like sh*t if you don't either have it hooked up properly, or block it off completely. Good luck.
#27
ok this is my question...i have two breathers plus pcv valve...if i put a pcv in the driver side and run it to my current pcv system with a T or double port....is this still considered a vac leak?
#28
So Vristang, I have some questions for you. I read a thread that you had going on another site, regarding pcv systems. I remember you mentioning that your separator bowl used to fill up like every 200 miles, before adding the second pcv. My question is, does this imply that your motor was on its deathbed...the fact that that much oil was being sucked into the intake? For reference, I've put 70 miles on mine, and it only has like a half a teaspoon in it. At any rate, does this always indicate that there is excessive blowby past the rings, or is there some other possible explanation? How long has it been since your discovery of your pcv issues, and has your motor continued to run well in spite of them?
My last question is, I've noticed that my car has been idling kind of funny (funnier than usual, anyway) since attaching the system. It seems to idle like 50 rpms lower, was surging like 50-100 rpms. It does seem to be getting better with time though. Why do you think my idle quality changed since adding the system. Also, I'm thinking about cutting the tip of the filter off. What are your thoughts on this? Sorry about all the questions.
One more request, when you get a chance, can you post that picture of your pcv setup again?
#29
ORIGINAL: grabbem88
