Boost or spray with this setup?
Old 11-01-2006, 10:11 PM
Champ561
Champ561's Avatar
Default Boost or spray with this setup?
I would rather s/c it but with the compression I thought I might be better off spraying. What do you guys think?
Engine:
Stock 93 Block bored .30 over. All oil returns chamfered. Crank polished. Rods fitted with ARP Wave Loc rod bolts. All Clevite Bearings (Rod, Main, Cam). Melling High Pressure Oil Pump. Keith Black Forged Pistons (10.25:1 compression). Hardened Oil Pump Shaft. Ford Motorsport Double Roller Timing Chain spinning a Motorosport "F" cam. New Timing Cover. New Water Pump. New Crankshaft Damper. New Motorsport Fox Body Chrome Oil Pan. AFR 185 Heads triple springed and Fererra Valves. Hardened Push Rods. ARP Head Studs. Motorsport 1.72 Roller Rockers. Edelbrock Performer Intake (Polished). Accufab 70mm Throttle Body(Polished). Motorsport Crome EFI Valve Covers. Motorsport Cold Air Intake. 130 Amp Alternator. BBK 1 3/4 Long Tube Headers. BBK Shorty H-Pipe. Flowmaster 3 chamber mufflers into dumps. All Gaskets are Fel Pro High Performance. New Belt and Pulleys. Black Magic Extreme 185 Cooling Fan w/ Control Module. 3 Row Radiator. Power Master High Torque Starter (Hitachi Style)
Champ561 is offline
Old 11-01-2006, 10:47 PM
Champ561
Champ561's Avatar
Default RE: Boost or spray with this setup?
BUMP
Champ561 is offline
Old 11-01-2006, 10:53 PM
nmerrill
nmerrill's Avatar
that is very high compression for boost. I think you are better off spraying
nmerrill is offline
Old 11-01-2006, 10:58 PM
Champ561
Champ561's Avatar
Exactly what I was thinking but then again if I do boost I am only gonna have 6psi.
Champ561 is offline
Old 11-01-2006, 11:07 PM
SSKiller
SSKiller's Avatar
Compression is a bit high, spray that bad boy.
SSKiller is offline
Old 11-02-2006, 12:01 AM
nmerrill
nmerrill's Avatar
10.25 is still high for 6 PSI. Worst case, you buy the blower, dont like it with the compression, and sell the blower to me i am in the market
nmerrill is offline
jwog666
12-27-2021 08:09 PM
Lethaldosage423
10-19-2015 12:12 AM
TCStangerv6
10-11-2015 05:57 PM
fastbackford351
10-01-2015 12:24 PM
guitarman376
09-30-2015 05:54 PM
Quick Reply: Boost or spray with this setup?
