Need A New Transmission- C4, AOD, Or C6? HELP!
RE: Need A New Transmission- C4, AOD, Or C6? HELP!
ORIGINAL: BlackLX
3000 stall, manual valve body, and 4.10s.
Simple physics...to get something you gotta give something up. Most guys with autos go with the 4.10's but you will give up some mileage. Also a transgo shift kit makes all the difference in an AOD. a 3K stall will add to the kick also.
Luck
Luck
It won't kill your gas mileage but it will go down a little bit. If you can't decide then just compromise and get 3.90s. Besides, you drive a v8 mustang, gas mileage should be the last thing you worry about.
I'm running 3.90s, custom built 3000 rpm stall, and I'm going to be ordering an Automatic/Manual valvbody within the next couple of weeks. This set up works great for a DD/weekend warrior.
ORIGINAL: 92hatchLX
C6 won't bolt up to a 302 anyways, made mostly for big blocks. Get an AOD.
ORIGINAL: BlackLX
bout my car.... mine is the one in my sig. the avatar is kona (the ring brothers car)
is there such a thing as a 5 (or more) speed automatic? or is AOD (4 speed) the most it goes?
