Does it go to the floor when you select floor? +1 on vacuum leak. I just went through this with mine and the yellow vacuum line came off the vacuum switch under the dash.
No, look up above the gas pedal and you'll see a bright yellow hose. Make sure that's hooked up. There's also a vacuum switch under the glove box which should have 4 or 5 vacuum tubes going to it. Make sure that all those are hooked up. Since it's not changing at all I'm leaning more towards a vacuum leak too. Check by the passenger side strut tower near the firewall and make sure that all those vacuum lines are hooked up. That's probably where it is.
