1.7 or 1.6 roller rockers??
if you dont exactly know what cam your going to go with, if your wanting kind of high numbers out of the cam is it just safer to run the 1.6 roller rockers. i know the 1.7 will give it a higher lift but still dont completely understand the difference between the two. any responses would help thanks
RE: 1.7 or 1.6 roller rockers??
5.0 mustang and superfords did in article on that. the 1.7 had the most hp but only by 2 but the 1.7 also where out ur valvs faster since it has a higher lift like u said. so if i were u i wood give up those 2 more hp and add some with the 1.6 and not have to worry about ur valves for a while. i have 1.6 and a cranes cam and im happy with it
1.7 rockers will give a little more lift than 1.6, if your building an engine you know exactly how much lift and duration you want - its really best to just go ahead and get the right cam and use 1.6's. 1.7's are a good idea if, for example, you are going to keep the stock cam but want alittle more power outta it or maybe you like the B cam but you want more lift, so you use the 1.7 rockers.
yea see ithink i want to go with a comp extreme energy cam, i think 1300-5600 rpm range sounds really good. 262/270 dur 493/500 lift. or should i go with i higher rpm range like 1600-5800 , 268/280 dur and 509/512 lift. would both of these have a good lopy sound at idle? these sound like good powerbands to me but which one would you guys suggest? and with a 1.6 rocker right?
WHAT!!! ford racing has them, lunati has them,crane cams has them..maybe u juss have looked in the right places...im from ct and i dont no if u guys have heard of them but theres a mustangs unlimited store hear and in georgia. u shood check out there rockers they got some good deals and they got everything ud ever need for a mustang mustangsunlimited.com/
