can someone help out with compression ratio
just checkin my builders work wondering if someone has a calculator or can calculate my compression ratio for my 347
heres the JE piston specs
Part # Cubic Inches Bore Stroke Rod length Block Height Compression Distance Head Cubic Centimeters DomeVolume GramWeight
56cc 60cc 64cc
compression ratio
170848 347 4.030 3.400 5.400 8.200 1.100 9.1 8.8 8.5 -22.0 415
i am running RHS 200s with 64cc combustion chamber, i belive the felpro metal head gaskets are like .041", and i think the block deck is like 0.012 or something like that
he said 9.2:1 but im gettin like 8.5 or 8.68
56cc 60cc 64cc
compression ratio
RE: can someone help out with compression ratio
How far down is the piston @ TDC? I used the following specs:
64cc chamber
Head gasket bore 4.002
Head gasket thickness 0.041
Piston Down from TDC 0.012
Volume above piston @ 1.10
I got 10.5:1
64cc chamber
I got 10.5:1
.012 in the hole deck height is not good. should always shoot for 0 deck on performance engine.
you can run into problems with too big of a quench area
C/R with:
4.03 bore
3.4 stroke
4.10 head gasket bore
.041 compressed thickness
64cc heads
22cc dish pistons
.012 deck clearance
= 8.29
you dont need that big of a dish unless you're shooting
for high psi boost.
C/R with:
4.03 bore
3.4 stroke
64cc heads
22cc dish pistons
.012 deck clearance
= 8.29
for high psi boost.
going to the dyno tomorrow to figure out why my headers are glowing red/orange either lean or rich and maybe burn a chip, just though i would like to figure it out for sure,, and yes going to boost the hell outta it
I used same calculator and came up with about 8.5 c/r
4.03 over bore
3.4 stroke
.041 compressed
64cc head
22cc dish piston
0 deck
that calculator does work too.
4.03 over bore
3.4 stroke
.041 compressed
64cc head
22cc dish piston
0 deck
