could i take him??
RE: could i take him??
ORIGINAL: chath_brick
also the stock intake on a 94-95 has an internal EGR, and that is your restriction, not your TB. your stock TB is the exact size of your EGR. a bigger TB does absolutely nothing on a stock 94-95 intake.
ORIGINAL: Ecstasy
you've got to downsize your tb, your actually slowing yourself down 75mm = way to big for your mods, 65mm will do for you, if you do a h/c/i swap then 70mm is fine i know people that still run 65mm but 75mm is pointless, and 3" exhaust is also not helping u. go with 2 1/2. 3" is only if your going to FI and you still dont need it then.
