stupid mistake!!!!!
stupid mistake!!!!!
may have messed up my motor today. i hooked up the heat to the wrong intake hole/air side. and the number 8 cylinder got loaded up with water. when i started it it knocked 2ce then i shut it off.... i took out spark plug and let it drain and im changin oil tommrow...
hopefully nothin is mesed up
im so pisseeddddd
im so pisseeddddd
RE: stupid mistake!!!!!
original:5.0stanger
What did you do? Pump antifreeze directly into your intake port? I don't know if I would have told that...
I wasn't trying to make ya feel bad, you did that yourself
Anyways about the car, if you wern't running a lot of rpms(just starting it right?) I think it will be fine. Roll it over with the plugs out to get the water out of the cylinder before you try and start it again
