94-95 Cobra Camshaft, same as 87-93 HO Cam?
Old 11-04-2006, 06:36 PM
89GTRed
89GTRed's Avatar
Default 94-95 Cobra Camshaft, same as 87-93 HO Cam?
is the 94-95 stock camshaft the same as 87-93 stock cam? Also is the 94-95 cobra cam the same as a normal 5.0 stock cam?
89GTRed is offline
Old 11-04-2006, 06:40 PM
primetime5.0
primetime5.0's Avatar
Default RE: 94-95 Cobra Camshaft, same as 87-93 HO Cam?
from what I remember they are a more aggressive cam
primetime5.0 is offline
Old 11-04-2006, 06:45 PM
nmerrill
nmerrill's Avatar
I dont know about the sn's being the same as foxes, but i do believe the cobra cam is different than a regular gt
nmerrill is offline
Old 11-04-2006, 07:05 PM
Ninety5five0
Ninety5five0's Avatar
Yea, they have more lift.
Ninety5five0 is offline
Old 11-04-2006, 07:26 PM
frdmstng1986GT
frdmstng1986GT's Avatar
i thinkthe only reason why they have more lift is because they use 1.7 rockers stock vs. 1.6. i might be wrong though.
frdmstng1986GT is offline
Old 11-04-2006, 08:57 PM
Mustangkiler
Mustangkiler's Avatar
considering they got the exact same hp ratings id have to say its the same as a 93 cobra cam
Mustangkiler is offline
Old 11-05-2006, 02:38 PM
Nadelle
Nadelle's Avatar
ok i just happen to know the specs.
85-95 5.0 HO 210/210 .444 .444 with 1.6 Rockers
93-95 Cobra 209/209 .486 .486 with 1.7
the cobra with 1.6 rockers would have a tad more lift than the old 5.0 cam, and one stinking less dagree of duration.
I could be a little bit off on the cobra lift specs but not by much
Nadelle is offline
Old 11-05-2006, 02:46 PM
8URWS6
8URWS6's Avatar
Do they have more lift or did Ford just put 1.7 rockers to make more lift? I know that they have a different duration, but I wasn't sure about the lift being that they used 1.7 rockers which increase the lift by .30.
ORIGINAL: Ninety5five0
8URWS6 is offline
Old 11-05-2006, 04:04 PM
OnyxCobra
OnyxCobra's Avatar
The cobra cam has more lift than the normal 5.0 HO cam before the addition of the 1.7s
OnyxCobra is offline
Old 11-05-2006, 04:43 PM
CrazyCobraSpeed
CrazyCobraSpeed's Avatar
onyx is rite i do believe are cobra cams are slitly more agressive and then rockers also help as well
CrazyCobraSpeed is offline
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
88 orangepeel notch
10-05-2015 09:03 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
NYstang
09-30-2015 09:56 PM
Quick Reply: 94-95 Cobra Camshaft, same as 87-93 HO Cam?
