ok,there are two "plugs" on the side of the trans... i dont remember if its pass or drivers, so just get up under there and look. bottom one is drain. and the top is the fill... drain it and then fill it to the bottom of the top hole, or about 1/4 inch below. and remember, tho its a manual, use ATF.
royal purple has fluid for automatic trans. and i think they have fluid for manual trans that require auto trans fluid... so yes you can use their stuff.
