OBD I or II?
#23
RE: OBD I or II?
ORIGINAL: LCBlackDep183
So would a multi-meter made for obd II work on a 95?
https://mustangforums.com/fb.asp?m=921609
#24
RE: OBD I or II?
There is an OBD II plug on the passanger side inside the car... I think it's there for the v6 model? It doesn't seem to be active on my car. I use the ODB I plug that is under the hood right behind the strut tower on the passanger side. It scans and gives me codes so I'm happy
well sort of I don't like the codes it gives me... but that's a different problem ;D
#25
RE: OBD I or II?
ORIGINAL: johan166
just repeat everything that everyone else has posted... its ok.... were used to people not paying attention on this forum
#29
RE: OBD I or II?
Parrot? since when is one person saying something is true enough to justify spending money?
and since no one answered, you can plug into the ODB I guages under the hood to get readings on stuff ;D... at least my scanner gives me all the info if I plug it in and run the engine
#30
RE: OBD I or II?
ORIGINAL: johan166
HE ASKED IF HIS OBD2 SCANNER WOULD WORK.... dumbass
TfcCDR
09-14-2015 12:08 PM
