Which should I do
Which should I do
I don't kno if I Should keep my 86 5.O HO EFI engine and go through changing my pistons to be able to get aftermarket heads OR just buy a brand new 302 that comes with gt-40 heads and new gt-40x piston heads and a b303 cam already installed so all I have to do is swap it right in. But the engine costs about 3600 Is this worth getting or am better off working with my 86 5.O HO EFI?
RE: Which should I do
get a new motor but get a stock 5.0 from 87^ thats what i am doing and then put afr's on it, u should be able to get a stock block for 300-500 bucks then the cost of the heads roller rockers and rods, then assemble it urself that is what i am doing, i was told to get new pistons and have the shop put them in is over 1800 but thats what i was told
Yea if u guys are doing a new motor, just do a 351w, then choose your path from there.
As you might already know the 351w fits in nicely and has a lot more possibilities further down the road. It also is stronger and can with hold more than our 302 blocks at around 450rwhp.
If your not the power-adder type of guy, get the 351w, stroke it, have a nice heads and cam combo with a few more natural aspiration mods, and you have one bad *** stang.
BOTTOM LINE: don't waste ur time with the 302 if your doing a swap, the 351w in my opinion is far more worthwhile.
