What's with my damn clutch?!!
RE: What's with my damn clutch?!!
Did the shop replace the throw out bearing retainer with a new steel unit? (The nose of the trans that the throwout bearing slides on) The stock aluminum one gets all grooved up and you could be hearing the bearing hanging up and poping loose from the grooves.
As mentioned above get the aluminum quadrant, firewall adjuster, and adjustable cable so you can control your clutch.
I had the stock quadrant break on my first 5.0 with only 3500 miles on it.
ORIGINAL: fourfivefour
Good luck, I would bet you would be okay..at least you get to drive yours, mine us up for winter already. How far do you push your clutch in before it makes the noise?
ORIGINAL: 5.0stanger
I was just thinking that maybe the pedal was going down too far. You reverse still grind even if you go 5th to reverse? I know that you know this, but R isn't synconized and will almost always grind.
junior04
09-28-2015 10:53 AM
ccdguy
09-19-2015 05:20 PM
