aftermarket amp install in a fox?
#61
RE: aftermarket amp install in a fox?
dude just run the rcas on the pass. side of the car and run the power wire on the driver side and you will never have any interferance just dont use to cheap of rcas you want the best rcas you can use for best sound quialty. doing this in a fox is pretty easy to im sure you wont have any probulms doing it good luck
#63
ORIGINAL: swiftfox90
#64
if your car is as loud as mine is buying cheaper RCA's isnt going to hurt anything, unless you are a true audiophile then you probably wont notice a difference esp in a creaky old 5.0
