wreckers t-5 tranny
wreckers t-5 tranny
ok i called the local junkys and they told me $125 for this t-5 trany but there going to test it for me and there going to get me to call thrus and there going to tell me if it works and if it does or doesn't i was thinking about buying a rebuild kit any body got an idea what i should get for an rebuild kit
RE: wreckers t-5 tranny
$125 for a T-5, I guarantee its fukt! A used one, thats in decent shape usually runs from $450 - $750. As for price on a rebuild kit, call Gforce, they have an awesome rebuild kit for the T-5, makes it capable of handling up to 500hp.
-P.
-P.
do you know anything about rebuilding transmissions???? a simple syncro rebuilt kit is $189 + shipping from http://www.ddperformance.com/t5_parts__upgrades.htm they are the company i get all my tranny parts from when i rebuild trannys for people. if you don't know how to rebuilt it or have never done it before i suggest letting some one else do it. there is more to it than every one thinks
the kits they sell that make it capable of 500hp would be a stock rebuilt kit.... the stock(1986 and newer) world class t-5 is rated at 500 ft. lbs. or torque.. trannys are rated in torque not hp... and yes a good t-5 fomr a junk yard should cost 500-700 ish g-force does offer a kit that allows the t-5 to handle more power but it isn't just a syncro rebuilt that includes needing stronger gears
ORIGINAL: P Zero
-P.
-P.
ok i live in canada but since it a pick and pull and i kno the guy that owns the place and he said usly its about $500 for them but hes thinking of moving he place so he crushing everything and said ill give it to u for 125$ and and the kit i was looking at is http://www.partsxdirect.com/part.aspx?aid=549 its from ford racing but not sure what kinda power it will handle. thx and no i have never rebuilt a tranny but frist time is the funn one rite
couldn't find the price on that page, but ford racing makes ok parts... and with a tranny there are so many little tricks and things liek that you'll spend about 1-3 days taking it apart and prolly 5-7 days putting it together, then you'll have to find the specs. for the backlash and then figure out how to set it where as i can take it apart and put it together set backlast etc. in about 1 1/2 hours if i work slowly, the fastest i did one was at a track for a friend 45 min.
wasn't read anywhere... i know a guy that worked for borg worner.. ford rated them at 300 incase they got a weak tranny.... the GM t-5 is actualy rated at less power than the trans am made stock but actualy took 300 ft. lbs if it was lucky the ford t-5 is much stronger than the GM one
