anything wrong with this setup
so i am planning on doing some mods pretty soon. This is how far I have thought it out.
Trickflow street heat intake
gt-40 or tf twisted wedge heads
Comp cam high energy camshaft Cam Specs
70mm bbk throttle body
75mm summit maf
after all that I will tune it and think about 24# injectors and so on....
i got links to the specs of any of the mods
what do yall think about this setup? should everything install smoothly and how do you all think the results will be? thanks
75mm summit maf
RE: anything wrong with this setup
Looks good that will make a sweet street car and should install easily but im not 100 percent positive on that cam the lift might be too high some one correct me if im wrong. I have a different cam (TFS1 never been used) and GT-40p heads that are milled and ported with stronger springs used once then taken off. Lemme know if your interested.
sounds like a decent combo to me. Im not sure who makes the summit MAF, but i would find out what you will have to do to it when you change injectors. I would go with a C&L, then all you will have to do is change the sample tube in it instead of getting a new sensor or having it reprogrammed.
