AOD..What can i do to make it better?
RE: AOD..What can i do to make it better?
by any chance do you have a boat ?
cuz the aod would be a free anchor , then you can swap to a t5
$2000 for -1 sec ET , only gonna see those gains dollar for dollar from nitrous. and everyone knows that **** will blow your car up fo sho do
lentech all the way if you insist, converter, vb and oil cooler. anything below 3000 stall you will be pi$$ed
ORIGINAL: BlackBetty93GT
aight...where do you get that at?
and id it hard to install?
also i see you have a trango shift kit...what is that?
ill make this easy for you
3000+ stall from www.edgeracingconverters.com
shift kit or manual valve body from www.lentechautomatics.com
hardened input shaft, alto red clutchs + kolene steels, A+ OD servo, 2" OD band from www.ford-aod.com
should hold 550-600hp
ORIGINAL: luckythirteen13
well you can buy a kit form that link. depending on your year it will range $370-$430. and that includes what they call a shift correction kit.
in pieces,
the input shaft is $164
they have the A+ servo for $143 but ebay has the A++ servo for about $100
clutches will cost you $208-$265 depending on your year
i plan to buy a lentech manual valve body for $470ish then either build it yourself or take it to a shop. labor will be $600+ for sure. more if the shop has to pull your tranny and reinstall it. itll be cheaper if you take the tranny out and take it to a shop.
in pieces,
