Coilovers
Old 11-08-2006, 01:42 AM
redmustang83596
redmustang83596's Avatar
Default Coilovers
What are the advantages of having a coil-over suspension as opposed to stock style suspension on a fox?
redmustang83596 is offline
Old 11-08-2006, 02:06 AM
redmustang83596
Default RE: Coilovers
any input on this?
Old 11-08-2006, 02:46 AM
redmustang83596
anyone? I've been looking at these front end suspension kits that come with tublar k-member and A-arms, but they also come with coilovers, would I want stock style springs or would I want coilovers for a drag/street setup.
Old 11-08-2006, 02:49 AM
86 5.0L
86 5.0L's Avatar
maximummotorsports.com
Coil-Over Tech
Make your Mustang's suspension perform at its best by replacing the stock springs with a Maximum Motorsports coil-over kit. Once thought of as a race car only item, coil-over suspensions are now considered the hot set-up for any highly tuned street car. A coil-over conversion provides the combination of incredible handling and great ride quality that one expects from a world-class performance car. Whether you are building a street car or a purebred race car, our coil-over kits provide the performance, strength, and durability necessary to handle the rigors of both the racetrack and daily driving. With a Maximum Motorsports Coil-Over Conversion Kit you will have the no-compromise handling you demand without paying a penalty in ride comfort. Switching to a MM Coil-Over Suspension System is a win-win situation for any Mustang!
Coil-over conversion kits eliminate the conventional stock springs that are located on the control arms, and replace them with compact, lightweight springs that fit over the struts and shocks. This is the optimum spring location for reducing suspension bind and unsprung weight. It provides completely free suspension movement with a drastic reduction in impact harshness. With a coil-over kit, your Mustang's performance and ride firmness can be precisely adjusted to suit your performance demands. A wide variety of readily available spring rates allow precise fine-tuning of your car's handling balance. An added bonus of coil-overs is that the ride quality will be better than it was when the car was still stock!
Vehicles being tuned for better handling performance can utilize spring rates that provide much higher wheel rates (see FAQ here for an explanation of this term) than stock, yet without the impact harshness associated with using stiffer than original equipment springs in the stock location. This improvement in ride quality is especially noticeable in the front suspension. The vehicle can also be lowered, with infinitely small increments of adjustment, and can be precisely corner-weighted. Excessive brake dive and body roll will be a thing of the past, allowing the vehicle to handle like never before.
Drag racers also benefit from installing coil-over kits. Besides the overall reduction in vehicle weight, coil-overs can increase weight transfer by providing bind-free suspension movement and the ability to use relatively soft springs. The ability of coil-overs to allow precise ride height adjustments also aids in tuning the vehicle for optimum performance. Whatever the ride height desired, whether it's stock or lowered, our coil-over kit can provide it.
Warning! All coil-over kits are not created equal. Compare the features of our application-specific kits with any other manufacturer's universal kits and you'll quickly see the differences. Careful attention to detail by our engineering team is why the MM coil-over kits avoid the design pitfalls of others. You can always depend on Maximum Motorsports to provide you with the very best parts for your Mustang!
We offer many features that set our coil-over kits apart from the rest:
* The underside of our exclusive MM upper spring perch is machined to allow the bumpstop to fit inside of it, increasing bump travel.
* The overall stack height of our coil-over kit's upper perch configuration is shorter than any other kit. This helps to maximize bump travel.
* If pre-loading the spring is necessary, the lower spring perch can be easily adjusted with a spanner wrench.
* A nylon-tipped setscrew ensures that the lower spring perch will not rotate.
* While other companies simply anodize their aluminum parts for appearance, we have critical components hard anodized for maximum life and easier adjustment.
* Overlooked by other companies, we designed our threaded sleeve assemblies to fit your vehicle's struts and shocks snugly. The tight fit keeps the threaded sleeve from rattling on the strut. More importantly, the lower spring perch is kept square to the strut and shock, preventing the spring from bowing and rubbing on the threaded sleeve.
* When you're ready to purchase, Maximum Motorsports will help you select the ideal spring for your performance needs, based on our extensive knowledge of spring rates, free lengths, and proper spring travel. Not only will we recommend a specific spring rate, but we will also recommend the proper length to prevent coil-bind. Coil-bind occurs when the coils of a spring bottom against each other before the suspension hits the bumpstops. This causes severe suspension system damage, and should never be allowed to occur.
* We sell only the highest quality coil-over springs available. While other companies lower the price of their kits by using cheaper springs, we choose to offer only the best. A quality spring, of the right specification, is the key to maximum suspension performance. More can be found about coil-over springs here.
* Made in the USA, our coil-over kit designs are second to none.
86 5.0L is offline
Old 11-08-2006, 03:00 AM
redmustang83596
ok ok i got it a little bit more, but like theres soo much going on with spring rates and what not. Wouldnt it just be better to get drag springs?
Old 11-08-2006, 03:03 AM
86 5.0L
86 5.0L's Avatar
ORIGINAL: redmustang83596
for drag racing yeah for cornering...... errrr......[&:]
86 5.0L is offline
Old 11-08-2006, 03:04 AM
redmustang83596
dont really care too much about cornering, im not going around corners fast in this car. So for drag racing, a set of drag springs would be better?
Old 11-08-2006, 03:12 AM
86 5.0L
86 5.0L's Avatar
theres other ways too
86 5.0L is offline
Old 11-08-2006, 03:23 AM
redmustang83596
like what?
Old 11-08-2006, 04:38 AM
mpswirl
mpswirl's Avatar
coil springs are good for drag racing also just use some lakewood struts with them.
mpswirl is offline
Quick Reply: Coilovers
