How should I spend $3000
Im thinking of goin with the Anderson Ford Motorsports Quick Kit:
Bassani BX headers $360.00
Bassani off road X-Pipe BX-5093-2 $239.00
Bassani Muffler turn down BX-5092R-4 $269.00
FRPP underdrives M-8509-A50 $95.00
Professional Prod. 75 T.B. 69215 $144.85
Professional Prod 75 EGR 69505 $36.42
90mm mass air w/Power Bell & filter $199.00 introductory price
Load IO with plug in $279.00
Anderson Power Pipe AF-0112c $232.00
The total is $1486.68
And I would like some Weld Draglites. Skinnies up front and fatties in the rear with Mickey thompson et drag radials.
Also a Pro 5.0 Shifter and I need a new clutch but dont know what one to go with. The car is a stock 89 hatch. So this is what I kinda wanna go with but If anybody has any comments or suggestions that would be great. Oh and I havent gotten any hp numbers from the anderson quick kit, so if you have an idea let me know. Thanx
RE: How should I spend $3000
ORIGINAL: MustangMadness7
For 3grand id buy the Trickflow top end kit, some gears, and exhaust. With that you can expect 260-280rwhp. The kit you mentioned will put you more toward the 220rwhp area.
bottom line. If you can break 300rwhp on a H/C/I combo... you messed up somewhere along the line
AFR165cc heads with 58cc chambers, trick flow stage 1 cam, harland sharpe 1.6 roller rockers, and a edlebrock performer RPM2 intake should take you to 300+ with a good tune
Luke9222
10-22-2015 11:55 PM
folivier
Tennessee Regional Chapter
10-02-2015 05:32 AM
