pcv is where?
RE: pcv is where?
The PCV valve is near the firewall on the lower intake manifold. It's kinda hard to see but if you stand on the passenger side and look behind the intake, you will see it on the bottom. It runs into a black rubber grommit and simply pops in and out. Sorry, I'd post a pic but its pouring out so I can't run out and snap one.
RE: pcv is where?
BTW, that screen thing under the PCV is the PCV filter element. I used a dentists pick to remove mine. If your babys got high mileage, im sure the element needs a good cleaning. It can be taken apart if you want to be really thorough, just bend the tabs back.
YoungStangsMan
09-05-2015 07:01 PM
