Switching pistons
Switching pistons
So as many members on here have the same problem as me with these damn flat top pistons, I was wondering if I could get some from an 87-92 engine and swap'em, seems too easy and probably wont work but I'd just thought of throwing it out there [&:]
RE: Switching pistons
ORIGINAL: AdderMk2
$800 gets you a new shortblock.... $350 more gets you forged pistons... $185 more gets you any aftermarket cam.. INSTALLED
just something to think about
ORIGINAL: 86 5.0L
[] lol, I was thinking of a budget way of diong it lol
ORIGINAL: AdderMk2
while its out, why not replace your main and con bearings?, what about your cam bearings? Whos going to do the assembling? How much are the new pistons going to cost you?
put a lil more thought into it, and youll see that MY way, ends up being a smarter choice. Although it may cost a little bit more, you get a professionally built 306-308, and you just have to drop it in and bolt stuff to it.
forged pistons are made from a solid block of metal. they are pressed while being heated and cooled, into a very dense smaller block. from there they are machined(cut) into the shape of a piston.
cast pistons are poured into a mold, then cooled.
trw pistons are actually a high pressure die cast that is then high pressure formed under a heat process
