Roller Engine
RE: Roller Engine
its a diff firing order, the non-ho has a hydraulic flat tappet cam, the ho has a hydraulic roller lifter cam. just pop your hood and look at your intake it should say 5.0 HO or not. other then that match your vin.
RE: Roller Engine
ORIGINAL: redmustang83596
can you swap the top end from an H.O. motor onto a non H.O. short block is the question im really asking? Assuming you change out the cam and related parts
RE: Roller Engine
ORIGINAL: Braydon619
yah i don't know my vin# and i don't have the little metal piece on my intake to tell me or not.
RE: Roller Engine
ORIGINAL: Ecstasy
i dont know if you can for sure or not, ive never did it, im sure its probably possible though. if you swapped out the necessary componets, the blocks are the same(i think)?
RE: Roller Engine
ORIGINAL: Ecstasy
wtf are you talking ab out go walk to your car and look by ur driverside dash itll be in the top left corner or if ur looking from by ur sideview mirror the bottom right, or look in the door jam on ur driver door or the title? dont be lazy.
see man i didn't know that... i can look for it as soon as this pinks episode is over (95 stang vs 84 {with nose conversion} mustang lol)
