h-PIPE QUESTION
Old 11-09-2006, 04:03 PM
iamvillani
iamvillani's Avatar
Default h-PIPE QUESTION
Does anyone know what i can plug the elbow tube on the h-pipe with where the smog pump line would normally hook upto? thanks
iamvillani is offline
Old 11-09-2006, 04:09 PM
Creetan
Creetan's Avatar
Default RE: h-PIPE QUESTION
From what I understand if you remove smog pump its best to remove cats too. The cats can get clogged up pretty fast with the smog pump gone. I would get an off road Hpipe and be done with it. Most off road pipes I seen didn't have a place for smog pump. I could be wrong maybe someone else can shine some light on this.
Creetan is offline
Old 11-09-2006, 04:19 PM
iamvillani
iamvillani's Avatar
i do have and o/r mac h-pipe but it still has the tube for the line to hook into...i can hear the exhaust coming out of it and i want to plug but i do not know with what.
Old 11-09-2006, 04:48 PM
Ninety5five0
Ninety5five0's Avatar
Is it a threaded hole ? If so just plug it with a screw....Or have someone weld it shut if you dont know how to weld...
Ninety5five0 is offline
Old 11-09-2006, 04:55 PM
ckyguy68
ckyguy68's Avatar
Go to your local hardware store and get a 3/4" vacuum plug. They are black and made of rubber. Ive had one on for 11,000 miles and it does the job.
ckyguy68 is offline
Old 11-09-2006, 04:59 PM
LX 90
LX 90's Avatar
i put a MAC pchamber in my car last weekend what we did was hit the end of elbow tube and treaded and old spark plug in there with locktight on it then broke the end of the plug off lol it works
LX 90 is offline
Old 11-09-2006, 05:01 PM
samseed101
samseed101's Avatar
You can use just about anything. It's not threaded, or at least shouldn't be. So just find anything that will hold and put it there. Perhaps find a huge bolt and weld it in there
samseed101 is offline
Ninety5five0
^ nicey handy work, i love lil tricks that work and are off the wall.
Old 11-09-2006, 05:07 PM
dillon1340
dillon1340's Avatar
here's what i did. i cut off the tube sticking out of the exhaust pipe. cut a piece an inch long off that tube. cut piece down side. flattened it out. brazed the flat piece over the hole. works and looks great!
dillon1340 is offline
Old 11-09-2006, 05:11 PM
iamvillani
iamvillani's Avatar
Thanks for all the advice....im suprised the rubber won't burn.....
Quick Reply: h-PIPE QUESTION
