400 rwhp 5.0 carb
RE: 400 rwhp 5.0 carb
first off u can get there but very hard, u need a nasty set of heads and a big cam, a nice intake u might have to go efi in fact get a newer block, and hope this helps
http://www.carcraft.com/techarticles...ngine_buildup/
ORIGINAL: 7upedition
hey reefer man... r u out of your f'in mind? (bad info) okay you can read a summit catalog, intake vs. what is commonly referred to as the lower intake in FI applications,(way to point that out jimmy neutron) also what heads are you using? 20-50hp...come on, 15 for a cam, your saying with "your" combo your only making an additional 87 hp.... wtf! Read the carcraft article (thanks for having my back blacklx)... and heres a lil info on heads, http://www.allfordmustangs.com/Detailed/630.shtml, and besides who has a mild 400hp mustang?
also keep in mind that in the article they tore the engine down and rebuilt it, slapping afr 165s onto a stock 83 bottom end will net you 50 hp to the rear wheels. go ahead, ask me how i know.
deffinately go with the stealth intake, cheap headers that do the trick are hedmans, i had them until i switched to the long tubers
and like i mentioned earlier, you will deffinately be wanting to switch out the transmission, clutch, and rear end if youre shooting for high horsepower
edit....and by bad info, i was refering to this
heads/cam/lower intake/carb.... easy 400hp
bradleyb
11-27-2015 07:50 PM
Matt's 95 Stang
10-05-2015 07:16 AM
