A/C Delete
Old 11-10-2006, 04:07 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
Default RE: A/C Delete
north no way...yes one off rt 250 in goochland
2 kwik is offline
Old 11-10-2006, 04:09 PM
hardcore91LX
hardcore91LX's Avatar
Cool im in need of a tune it really didnt matter which way I went since its about the same distince both ways. Do you have any info on the shop.
hardcore91LX is offline
Old 11-10-2006, 04:43 PM
5IVE.OH
5IVE.OH's Avatar
You don't lose or gain any HP with AC. The power is always there, it's just free'd up is all. Same as a windage tray in the oil pan, doesn't add power, it just free's it up.
5IVE.OH is offline
Old 11-10-2006, 05:23 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
where you at?
2 kwik is offline
Old 11-10-2006, 05:35 PM
P Zero
P Zero's Avatar
Removing the a/c I also used rubber plugs. Couple of things to think about, instead of an a/c delete kit, get yourself a ps pump bracket for a non a/c car, bolt it (it sets the PS pump closer to the middle of the engine and up a little higher too). Also, youre going to need a shorter belt. Mine is 69.5", the crank is UD and there is no smog pump, so if you have the stock crank pulley add about 2", but if your smog pump is there, get a piece of string run it around all the pullies like how the belt would go and thatll get you in the ball park.
-P.
P Zero is offline
Old 11-10-2006, 05:38 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
you don't need a A/C delete kit why becuase mustang did come without a/c and can just use that belt...NAPA has them
2 kwik is offline
Old 11-10-2006, 07:21 PM
hardcore91LX
just 10 min north of harrisonburg
ORIGINAL: 2 kwik
where you at?
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
69Volunteer
09-30-2015 10:39 AM
DtRockstar1
Mustang Videos
09-27-2015 07:46 PM
Quick Reply: A/C Delete
